Rear Windows and Both Sunroofs not working
Hi All ,
Today I replaced my XYZ switch and all was well. I went to the car wash feeling all pumped about my switch being fixed and after I was done I opened all the windows and sunroofs. I got home and closed my front windows with no issues and then noticed my rear windows wouldnt close. I tried to close my sunroofs and neither would close. I know the motors are good. I also recently replaced the window switches. I checked the fuse box and verified fuse # 11/12/13 all weren't blown. I really don't know what to do from here.... I would really appreciate your help!!!
Hopefully you've found the problem by now but I think the reason you go no responses is because this is a common D2 problem and there are hundreds of posts on it. However if you have not found this out you can "google" Discovery 2 BCU and learn. There are many failure modes for the rear windows from switches to wiring to motors. However when the sunroofs and both windows stop at once you're liking dealing with a BCU failure.
