Removal of lower plastic engine cover
Actually, I think it may help with cooling the engine. With the guide installed and the hood closed in makes a "tunnel" that directs air over the radiator and manifolds, and down the back of the firewall.
I pulled mine off 2 weeks ago to replace the oil pan gasket, etc. I left it off because I wanted to make sure there were no leaks afterwards. Anyway, after removing the air guide I'm running about 2 degrees hotter on average on my ultra gauge.
This weekend I'll be installing oil pressure and coolant gauges from glow shift, I'll put the air guide back on and see if it makes a difference.
Removal
Jack up your truck under the cross member and it should spread the steering rods apart enough to slide it out, worked for me at least. It is nice to have out,spotting leaks and other maintained is a breeze, doesn't really seem any dirtier under there and if anything it's easier to clean anyway
Pics?
Abran, can you snap a couple of shots of the two different types of lower engine covers?
