Removing oil pan; DI - Land Rover Forums - Land Rover Enthusiast Forum
Old 11-10-2009, 01:37 PM
tornado_735's Avatar
Senior Member
Default Oil Pan Removal; D1
I am about to remove the oil pan from my DI. Will I be able to get it out of there without having to tear all the suspension and steering linkage out?
Old 11-10-2009, 02:26 PM
XCELLER8's Avatar
Senior Member
nobody said it would be easy, but when I did mine the easiest way was to remove the ball joint from the driver's side spindle assy, and remove the steering stabilizer to swing the steering arm down and out of the way.
Old 11-10-2009, 02:51 PM
Senior Member
Stuck right now...any advice on how to remove the two pan bolts at the back where the motor meets the bell housing?
Old 11-10-2009, 03:16 PM
XCELLER8's Avatar
Senior Member
Oh yeah, THOSE two bolts. thin wall socket ,( like a 1/4" drive) and a long extension. I can't recall the exact chain of swear words I used but with a little practice I'm sure you'll find the right combo. good luck
Old 11-10-2009, 03:19 PM
Senior Member
Quote:
lmfao a friend of mine said to remove the transmission inspection cover, and that will make it easier too. Thanks!
Old 11-10-2009, 04:00 PM
jycsalas's Avatar
I did this a week ago.
I removed the steering stabilizer and lowered the sway bar by removing the brackets that hold it up. (in red circle)
I also jacked up the DI from at the chasis a little bit to the rear of where the sway bar is mounted. That gave me a lot more clearance between the axle and oil pan.
Old 11-10-2009, 04:13 PM
salve7's Avatar
Senior Member
Josh, How did you get that pic from the rave cd? I can not for the life of me remember how to do a screen shot on my pc... It would help when I post questions.
Old 11-10-2009, 04:18 PM
Senior Member
Quote:
To get a screenshot, press "print screen" on your keyboard, open paint or some other imaging software and paste it.
Old 11-10-2009, 04:23 PM
jycsalas's Avatar
To get a shot of the ACTIVE window press: Ctrl, Alt, print screen
To get a shot of all windows press: Ctrl, print Screen
Old 11-10-2009, 05:09 PM
salve7's Avatar
Senior Member
Thanks! Sorry to hijack...
Thread Thread Starter Forum Replies Last Post
Need assistance removing D1 tranny pan and filler tube chicane Discovery I 17 03-02-2014 09:45 PM
removing oil pan charlesnj6 Engine & Internal 6 06-17-2012 10:23 PM
removing oil pan.. blue gasket sealant... ngarover Discovery I 15 04-16-2012 10:48 PM
$10 Oil Pan jconway Engine & Internal 1 06-20-2005 04:22 PM
$10 Oil Pan jconway Private For Sale/Trade Classifieds 1 06-20-2005 04:21 PM
Tags
box, cd, cherokee, di, jeep, land, landrover, leak, oil, pan, pictures, print, rave, remove, rover, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
