Replacing Ignition Switch.. HELP!
Old 10-16-2007, 11:19 PM
alverez's Avatar
Default Replacing Ignition Switch.. HELP!
Does anyone know how to get the bolts off the ignition switch on the steering wheel column of a 96 discovery? They look factory installed and I have no idea how to get them off. And besides that what are any other details I need to know when replacing an ignition switch? I can't turn the key and in the process locked the steering wheel. I am currently trying to sellthis truck but I think I may get more if it runs.. just a hunch. Thanks!
Carlos
Old 10-17-2007, 09:29 AM
okdiscoguy's Avatar
Default RE: Replacing Ignition Switch.. HELP!
They are anti-theft bolts. You can try taking a small pair of vice-grips and turning, or you can drill them out and re-tap them.
Old 11-15-2008, 01:47 PM
yohar's Avatar
You can also cut a slot in the top of the anti theft bolts and remove with a screw driver.
Old 11-17-2008, 12:49 AM
CandiMan's Avatar
Or use a small chisel and try to tap the bolt loose.
Old 11-17-2008, 10:43 PM
tacomatech's Avatar
Hammer and chisel work the best.
jfarnsley
04-07-2014 08:03 AM
disco1noob
10-06-2013 07:10 PM
georgep
11-01-2012 10:13 PM
DiscoJonny
04-28-2012 07:21 PM
chrisusvi
04-27-2007 01:39 PM
Quick Reply: Replacing Ignition Switch.. HELP!
