Sai pump makes wierd sound
#31
#33
Success!
I bought and installed a re-built air pump and it solved my problem. The one I bought, is below. It fits perfectly and costs $139. You have to send your used one back as a core.
Landrover Discovery 1999-2004 Secondary Air Pump Rebuilt - Rebuilt Air Pump.com
I no longer have an extremely loud blower noise at start-up! The install takes about 20 minutes (5 bolts).
The filter on my old one was in perfect condition, so I am assuming it was the bearing.
#34
Hi all, I have a D2 2004 V8. I also have a louder noise in the morning, that goes away after about 1 minute. I understand this is normal (though earlier I didn't have this noise). Now I also have a Check Engine light and the garage says the diagnostics show "Secondary Air Pump" problem. What should I do? BTW, I had the light reset, but the light comes bach on after a few minutes. What should I do?
thanks
thanks
#35
Just popped P0418 04 D2 w/SAI- SAI initiated after driving 3 miles and began its normal screaming routine. Turning it off again and the fault is sustained with SAI staying engaged. Can i run with it temporarily like this or unplug it and be ok ( understanding that cold starts might be different)
andrewcloy
09-10-2007 08:27 AM
