SAI tube thread size
Old 05-22-2014, 08:17 PM
RicketyTick's Avatar
Default SAI tube thread size
Anybody know the thread size on the SAI tube that screws into the head. I have set of heads that have two of the holes (one on each head) that have bad threads and wanted to see what I could do to fix it. Is there much pressure on those like on spark plug holes? any ideas on how to fix them? two fit tight and two snug up at the bottom of the holes, but are kinda loose fitting untill the last few turns.
thanks
Old 11-26-2014, 12:22 AM
RSPTex's Avatar
thanks
Hey, did you ever find out what the thread spec is? I need to make or buy plugs for it. I'm switching ECUs to one without SAI and I have to get rid of the stupid system.
Old 11-26-2014, 12:51 PM
04duxlr's Avatar
I've seen people delete the SAI by taking the threaded couplers off the pipe, welding them shut and then threading them back in.
The_OGCJR (06-23-2022)
Old 11-26-2014, 06:32 PM
RSPTex's Avatar
Thanks dux.
My main reasoning for wanting a threaded solution is because I want to be able to switch ecu's quickly at the shop. I'd guess they have a welder, but I'm not certain. I guess I could take it out now and then have a CEL while having the transmission replaced and then drive it the 5 miles to the shop to have the ECUs swapped out.
That should be fine.
Old 11-26-2014, 09:18 PM
04duxlr's Avatar
Another option would be to measure the tube diameter then buy an NPT tap that would be about that size. Then pull the threaded pieces off the tubes, tap them and thread in a plug then thread the pieces back into the head. Or you could get a compression fitting and plug that you could install on the cut tube, or pull off the cans and bolt a block off plate over the flange, or you could just leave the cans in place because they will stay closed without a source of vacuum.
Old 11-27-2014, 05:54 PM
5/8 x 20tpi or m16 x 1.25
Old 11-27-2014, 06:24 PM
RSPTex's Avatar
Hey Ricketytick,
Thanks! Is that the male threads for a plug, or the female threads to cap the SAI extension?
btw, Happy Thanksgiving!
Old 11-27-2014, 06:29 PM
Hey Ricketytick,
Male into the head.
Thanks and hope you had a happy TG also
Thekid
09-20-2012 07:53 AM
DooDer
05-12-2012 02:40 PM
sbaldwin243
03-25-2011 10:04 AM
Bryan H
07-23-2010 02:39 PM
Antmen
05-22-2010 05:19 PM
Quick Reply: SAI tube thread size
