If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
Need Parts? paulgrant@mac.com, or 203-770-1699 willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
I'm not normally the crass, cynical type, but let me get this straight...
You've been a member for 5 years, and you live in Great Britain, home of the rover. And you're looking for recommendations regarding an oil change?
I won't feel too bad about my code questions any more...
DRW
__________________
2001 Disco II, 108K current miles. High mileage maintenance at 98K miles. SS brake lines; Tom Woods drive shaft; new O2 sensors, battery, crank position sensor; replaced many hoses as preventive maintenance. Option B modulator fix with new assembly/seals/circlips from Falconworks. New water pump, tensioner pulley, serpentine belt, fan, purge valve, timing cover gasket. Akebono brake pads. Hood blackout, Herculiner on bumpers and fender flares. Painted headliner & interior enhancements.
