If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
what it the actual name of this stuff and where are you getting it?
__________________
00 Disco 4.0 80k miles SLS, ACE, 7 passenger 255x65x18: Repairs since 02/11 new intake, valve cover, head, timing cover, waterpump & oil sump gaskets, new timing chain & gears, water pump, t-stat, hoses, belt, new front drive shaft, Akebono pads, D&S rotors, SS brake lines, clutch fan, HMS completed.
90 RRC County
67 mustang GTA
73 Jeepster Commandos
69 Honda SOHC
71 HD FX
72 BSA Lightning
73 Honda SOHC
78 Honda SS
87 HD FLTP
2004 HD SE 103
He who dies with the most toys, WINS
__________________
90 RRC County
67 mustang GTA
69 Honda SOHC
71 HD FX
72 BSA Lightning
73 Honda SOHC
78 Honda SS
87 HD FLTP
2004 HD SE 103
Need Parts? paulgrant@mac.com, or 203-770-1699 willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Those who have used white shepard in their land rovers, what has been your experience, success rate with this product?
__________________
'03 HSE7 112k driveshaft/headgasket/water pump/oil pump/all fluids akebone pads and new rotors and I have almost had it a year
'02 pathfinder 160k
'89 yota 4x4 251k
First of all, they make 8 different products.
I have used their oil stop leak in both my t/case and rear diff with great no more leak results. I have used theit p/s stop leak over a year ago and as long as it is not a hose leak it will stop leaks in the p/s pump as well as the gear box. They make a great rear main sealer that I have seen used with pretty good results. I have not used either of their a/s stop leaks and tell everybody to not use the Blue Devils coolant stop leak, it is a terrible product.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
I used the rear main seal stop leak with no success. It sure was worth the $13 gamble which could have saved me from yanking an engine again.
__________________
2004 Vienna Green SE Discovery 80K, Aftermarket Oil Pressure and Temp gauge warning system, Head gaskets replaced 09'. 2011' Turner Reman Block, Heads Overhauld, Crank machined, New Bearings, Front Cover, Pistion Rings, New Cam/lifters, Timing set,All new Hoses, Radiator/Thermo and much more.
2003 Oslo Blue SE7 Discovery 60K, Aftermarket Oil Pressure and Temp warning system, New Radiator, Thermostat
looking at the rear main seal stop leak for my wife 3.9, to cold & to lazy to be pulling a motor in January
__________________
90 RRC County
67 mustang GTA
69 Honda SOHC
71 HD FX
72 BSA Lightning
73 Honda SOHC
78 Honda SS
87 HD FLTP
2004 HD SE 103
