Shocks question
Shocks question
So, I'm running OME 751 springs in the front of my D2. This gives a little extra lift over the 779 typically used. I'm curious about the right shocks. The 60024 is the typical shock used (says for vehicles with up to 1.5" lift), but I see there is a 60024L available as well for longer travel. Anyone got any intel on the best option for my application?
Thanks as always!
-Gavin
Thanks as always!
-Gavin
Im just curious as well. Isnt it that the OME nitocharger fits well with that application? I got the 1.5 OME from AB for a while now and recently I replaced the nitorcharger with the newer version of the nitrocharger. Im not familiar with the numbers but I remember that if you will get a longer travel, you also have to upgrade to longer brake lines.
G150driver (12-06-2016)
Interesting. OK, well I am like a tweener, I guess.
OME 751s in front (dual batts and a discrete winch w/ synthetic line) and 781s in back (plus D1 perches) I'm probably about 2.5" above stock height. Already running extended SS brake lines, so no worries there. But I suppose I'll just go with the regular travel since my vehicle isn't getting lighter with time and I'm certainly not looking to make it any taller...
Thanks for the feedback!
