Sold all my tools when I moved, what tools will I need to replace front rotors?
i got a tool off ebay to help remove the philips screw that holds the rotor on. other wise probably one the easiest brakes iv ever changed.
here is the tool i got off ebay
Craftsman 1/2 in. Drive Manual Hand Impact Driver Tool Set 4 Bits & Adapter USA | eBay
JUKE179r (12-08-2016)
Received 1,160 Likes
on
If you can't get the philips screw out, just drill the head off with a 3/8's bit. Once the rotor is off, try to remove the rest...if it doesn't come out...no biggy...it is basically just an alignment bolt to hold the rotor in place, while the vehicle goes down the assembly line until wheel goes on. Does nothing more than that, and isn't necessary or important for reassembly.
Brian.
Brian.
Brian.
Brian.
I did the ebc heavy duty rotors and pad on mine and they were a breeze. The back rotors still had the Phillips head screws in them but the front were missing. I replaced them all just BC I am OCD but I put anti sieze on them to help when it comes time again. It is a fairly simple job as long as you have a good metric hand tool and ratchet set. Nothing really TOO it but make sure when you pry the pads back or use a tool to compress the caliperto it's fully seated position, you open the cap on you master cylinder so it doesn't blow out. After I did the rear, I closed the cap and pumped the brakes up to lower the brake fluid level then reopened the cap and did the front. Don't want that stuff going everywhere or it will eat at paint like an acid etcher.
+1 for the impact driver. It helps with rusty and/or seized screws and bolts.
wantstoknow
03-01-2011 11:29 PM
lipadj46
11-15-2009 05:59 AM
charlypm
04-15-2007 02:32 PM
General Hague
10-11-2005 04:42 PM
