gave up on the stock head unit
couldnt get i working i lost power in the radio harness how do i run a new power to the new aftermarket head unit i wired all of the unit but still no power so i want to run a new wire from the battery do i need to put a fuse on the line or just straight from the battery to the head unit the new head unit is a kenwood thanks for the help
Yes you need a fuse inline between the battery and the radio. You need to find a switched source to pull power from for your radio or you risk leaving the radio on and killing the battery.
Are you getting sound at all or just not from the sources you mentioned? If the tuner is working then the problem is inside your head unit. If no sound at all you need to use a converter to convert your speaker outputs to a signal the factory amps can use. Crutchfield sells the converter for about $30.
boxeo75
02-15-2013 11:47 AM
AustinMiniMan
07-30-2010 03:08 PM
