Sport Mode button
Sport Mode button
We have an 02 Series II and the sport mode button at the bottom of the transmission shifter doesn't seem to be working, is there a light or something that would tell me that it is engaged or an audible tone to let me know it is working? If there is, what steps should I take to find out how to fix this problem?\
Thanks in advance,
Ryan
Thanks in advance,
Ryan
RE: Sport Mode button
ORIGINAL: NWDiscoRover2004
When activated there should be a green "S" with picture of a ring gear illuminated on the dash. Likewise, when in 4-lo if you push the same button an "m" will illuminate indicating manual mode.
ORIGINAL: Disco Mike
Is your check engine light or other warning like on, if so what are the fault codes?
Currently looking for a PDF version of this so called RAVE CD...
I have a 200for disco too and I can get the sport mode to come on just fine but I’m not sure what you mean in your description of how to access the full manual mode. I know that my light indicator works because whenever it cycles on that light illuminates. Do you have any thoughts?
