Steering wheel shake
Ok. The disco's got a shake in the steering wheel. There is no specific time when it happens, it can be cold, warm, going around a corner . . .
My hubby put a new steering shock on it the other week and it doesn't seem any better.
Any thoughts ?? I'm wondering if it could be the tires might need to be balanced or could I have suspension issues?
Thanks !
Thanks !
The tire wear is uniform and they have a decent amount of tread left. Wouldn't a bad ball joint make some noise? I'll have him check what you've mentioned.
I was thinking it could be the tires; they are mismatched. My hubby has decided to buy four new tires, but he's not sure what brand. Any recommendations ?
Great Tires--- Bridgestone Dueler A/T Revo 2's
Hello,
I did some tire research about 9 months ago and wanted a good A/T that other trucks and Land Rover users were running. After a lot research I decided on the Bridgstone Dueler A/T Revo 2. 245/70/16. If you look at that tire on Tirerack.com it is about # 3 in its ranking among reviewers. I think any tire in the top 10 ten is good. But what sold me is 12 other Land Rover users reviewed that tire. I found it locally for about $150 -$160 each.. They are not cheap but I really like my set. I even found a used spare to match on eBay for about $50. There are 76million miles on these from people cumulativly reviewing them. I have had them off road about 4 times and dropped the PSI to 20 they did well.
Here is a really helpful guide that I used as the Bible when I was making a decision.
http://www.tirerack.com/tires/survey....jsp?type=ORAT
