stepper motor (IAC valve)
RE: stepper motor (IAC valve)
Here is the best way to clean the t-body.
Run the right front tire up onto a curb or a piece of wood, then just take your can of carb cleaner and spray away.
Everything will run inside the intake plenum and burn off when you start the truck.
After you clean it really good drive the truck around the block a couple of times.
And no, the gunk will not hurt anything.
But if all of that carb cleaner pools on the top of your engine it can smoke/catch fire when you drive.
