Stripped torx bolt.
Stripped torx bolt.
Finally got around to changing the ATF filter with a slight hang up. One bolt
was stripped. Didn't have time to monkey around so I put back the other torx bolt and replaced the pan gasket. Other than notching the bolt head, and using a large screw driver and / or tapping the notch on the edge CCW to unscrew, any other ideas?
