Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 01-26-2012, 11:01 AM
dcarr1971's Avatar
Senior Member
Default Swapping in 04 transfer case...extra switch?
OK gentlemen, I've tried searching to no avail...one of my friends has a '00 D2 that a PO had replaced the T-case in. The replacement T-case didn't have the CDL nipple, so my friend sourced an '04 transfer case to replace it and will be installing a D1 transfer case shifter assembly.
We pulled the old t-case last night and have determined that the new '04 T-case has a couple additional Warning Lamp switches.
My questions are,
- Which of the switches 2 should he be using? (See picture. Both red and green arrows point to a Warning Lamp Switch that wasn't present on the old (non-CDL) T-case.)
- Does anyone have a picture of the connectors for the switch? The connector is cut off from the switches on the new t-case, so we need to find the corresponding connector in the harness and solder a new one in.
__________________
Dave
Pittsburgh, PA
1999 Land Rover Disco II - 118k miles, Locking CDL from a D1, SD Rack, 3rd Row added, 255 85r16 BFG KM2's, TerraFirma 3" lift w/ TF +2 shocks, QT front diff guard, Southdowne rear diff guard, fuel tank skid...more to come...
1996 Disco I "Red" 5-Spd - 120k miles, 2" OME lift, X-Brake, just getting started...
Rave download: http://www.landroverresource.com/
Fort Pitt Land Rover Group
Old 01-26-2012, 12:32 PM
Senior Member
It may be a switch(s) to tell tranny ECU or SLABS that you have the TC in low, etc. See attached.
__________________
Old 01-26-2012, 01:11 PM
Member
Hey dcarr, I believe that those switches are for the Diff lock indicator lamp and the 3 chime audible warning. The earlier model t-case only had one switch. Hope this helps. JF
__________________
2004 Disco II SE, 101k miles
Old 01-27-2012, 10:31 AM
Senior Member
On the '04 both are wired in parallel. You should be good to go if you just use the forward / LH in the photo switch only. One wire to ground and one to the SALBS input. Have a look at the wiring diagrams and decide where you want to make the connections.
__________________
'03 D2
Super Pro Bushes; Was Koni HT, now HT RAID; Detroit Rear & TT Front; CDL then Quife torque biasing center diff; Style A Wheels; Scorpion ATRs; Goodridge Stainless Lines; EBC YellowStuff on DBA 4000XS; Big Valve Heads; 202 Cam; Stroked to 4.8L; Tuned Motronic; Added ACE & SLS; Euro Headlamps W/ Leveling & Powerfold Mirrors. Forced induction coming next.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
