TD5 injector problems. - Land Rover Forums - Land Rover Enthusiast Forum
Old 03-20-2008, 10:22 AM
Junior Member
Default TD5 injector problems.
Dear Forum, I have a Disco TD5 -00 and had to change to a new cylinder head due to internal crack.
With the new head in place the engine started knock after a few miles. The fuel injectors were checked with a connected computer and three of them were found indicating outside margins. The bad injectors were replaced by three used ones. The car starts now butt engine is running very rough.
Now the shop asks to exchange all five ejectors to new ones, a pretty costly swap in view of what I already have spent to get the new top in place, and all five injectors worked fine until then.
My question to the Forum is, - can the injectors be tested on a bench outside the engine, if so where?
There are other factors, like programming of each injector and setting proper valve play, but I have to thrust the professionalism of the Landrover shop. Resid Stockholm, Sweden.
Happy Easter, from “discoper”.
Thread Thread Starter Forum Replies Last Post
Disco TD5 Misfire/Cut-out - New TD5 Owner - Please Help?! pgaukroger Discovery II 7 02-29-2016 06:56 AM
Injector problems on Disco TD5 2002 Willem Swan General Tech Help 2 06-27-2012 11:44 AM
Fuel Injector problems? narich88 Discovery I 3 06-21-2012 12:10 PM
Freelander TD4 injector problems gmca01 Freelander 4 06-07-2012 03:03 PM
90" Td5 Vs. 110" Td5 Defender trini defender Defender 1 12-11-2006 06:14 AM
Tags
change, discovery, fuel, injector, injectores, injectors, knock, land, landrover, problems, problen, programming, rover, td5, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
