09-24-2007, 02:59 PM
Junior Member
THREE AMIGOS FIX
Good day, I recently purchased a 00 Discovery II. How can I determine what exactly is causing the three amigos, and are there any scanners out there that can read or clear the fault codes? My goal is to resolve this cheap! Any direction will be much appreciated as this is my first L.R.
09-24-2007, 03:32 PM
Senior Member
RE: THREE AMIGOS FIX
The codes have to be read by a shop with a Testbook capable scanner. This is what the dealer has. There are others that can do it, rovacom, autologic, but your run of the mill shop won't have it. Needs to be a rover shop. If you can't find one, call atlantic british and they will tell you where the closest autologic shop is..
Good Luck!
__________________
RAVE
Good Oil
2003 Range Rover HSE with 2008 trim
2010 GLK 350 Mercedes
1990 VW Cabriolet - Lake car...
1997 Discovery SD-7 to put the boat in.
09-25-2007, 05:36 AM
Junior Member
Thanks, is there anything I can do to prevent this from happening in the future?
09-25-2007, 08:22 AM
Nope, the Bosch ABS is just very sensitive and can be tripped easily. Some Rovers are not as bad as others, brake dust and how you drive has a little to do with it.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Tags
00, 2003, abs, amigos, discovery, fix, freelander, ii, land, landrover, lr3, repair, rover, three, understand  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
