Throttle Body Heater Kit Install
RE: Throttle Body Heater Kit Install
Yes you should have used a gasket.
The purpose of the the t-body heater is to keep it from iceing up in cold and high humidity.
Cold air is rushing past the t-body and it is REALLY cold in the winter, and when it is moisture laden it will form ice crystalson anything that it can. If it is bad enough it can cause the throttle to swtick open, or the engine to not get enough air.
Not a problem where it is warm, but they have no idea what you are going to do with your truck. Hell, you might drive it to the Artic Circle for all they know.
Does that answer your questions?
