tire pressure
Old 12-31-2004, 04:28 PM
kensei's Avatar
4th Gear
Default tire pressure
What would be the correct tire running pressure for my 03 disco? Iam getting conflicting info.
Old 01-01-2005, 01:11 AM
berg7171's Avatar
4wd High
Default RE: tire pressure
Check your owners manual but I have a 01' Disco and it calls for 28psi in the front and 38psi in the rear. I am running the Goodyear Wrangler HP 255/55r16. Hope this helps should be the same in '03.
Old 01-01-2005, 03:08 AM
kensei's Avatar
4th Gear
Hey thanks for some input berg, I had checked my manual and just thought the numbers sounded off. 30 front and 38 in the rear...who am I to question the owners tech manual though?
Old 01-01-2005, 09:01 AM
Lighting90's Avatar
The manual is correct, the reson for the high pressure at the back is to allow for the extra carry weight. Don't forget your disco is capable of pulling another 3.5 tonnes of trailer behind it.
Glad you sorted it Berg.
anthonyb
02-15-2007 11:45 AM
oncorhynchus
01-21-2007 02:14 PM
lpx
01-15-2007 06:57 AM
agavrilo
11-16-2006 12:19 AM
T3LU_03
06-08-2006 03:18 PM
Quick Reply: tire pressure
