Top end engine rebuild w/ pics and video
#21
Cylinder head is off!!! Video!!!
LMAO, these sockets are worth their weight in gold.
Good news! One of the heads is off!! And I do not see evidence of a slipped liner! The blowout is not between the cylinder walls. Video below, thanks to everyone for their help!
#22
2003DiscoAZ (03-05-2015)
#23
#24
#25
#26
If I can get 75k, this will have been time well spent!
I will grab the recommended head bolts. I would like to avoid another head gasket job, but having gained some experience with this job am confident that I will be able to tackle another one in the future, thanks.
Could you provide a link to the correct part? I still have not been able to remove the multiplug from the plenum.. How does this thing come off? Oh, and what should I have the machine shop do, resurface heads, full valve job, anything else?
You guys rock!
You guys rock!
#27
what you have done to your head depend upon your milage, under 100k you're probably all right just having them decked.
If you're much high than that you could have a valve job done, which ever one of you do it make sure you replace the valve guide seals that will come with the gasket kit.
ARP should list two numbers one for older rovers 14-bolt heads and one for newer rovers 10 bolt heads, the older set will give you 8 extra studs for less money than the newer set. check the numbers
#28
#29
About the head bolts/studs? I just realized that I bought these from AB. If these are prone to failure I will get ARP 157-4301
Land Rover Head Bolt Kit (Same fit as Part # ERR2943) Fits Discovery, Range Rover & Defender Vehicles
#30
that's a decision you will have to make yourself if you want to use bolts or studs.
Personally i would use studs, i believe a lot of these junk blocks are caused by the people replacing the head gaskets.
they jerk the bolts tight, use extension bars, cheater bars and what not because they can not evenly apply the proper pressure to smoothly tighten the bolt. which cracks the hole in the block but thats just my theroy
