Top Hat 4.6 SAI Long Block Engine
Old 07-18-2016, 11:34 AM
Fast951's Avatar
Default Top Hat 4.6 SAI Long Block Engine
Would anyone be interested in a completely rebuilt Top Hat engine? I have two 4.6 SAI blocks that I'm considering having fitted with either Darton or LA Sleeve o-ring liners with original bore dimension.
The engine would be completely rebuilt meaning heads surfaced with entirely new valvetrain, new head gaskets, new head hardware, new tappets, new push rods, crank polished, new crank bearings, new con rod bearings, new piston rings, new cam, new cam bearings, new main seals, new oil pump, new timing gears and chain, new coolant pump, new freeze plugs, new cross bolt seals, etc.
This is how Atlantic British does their rebuilds, except without the Top Hat liners and they get $7,195 for them + they require a core or it costs an extra $1,250.
Again, just trying to get a sense for the level of interest before beginning another project.
Old 07-18-2016, 12:08 PM
abran's Avatar
According to their site the engines include "flanged sleeves".
But I am sure you can beat their price by a good margin and make a small profit.
Q&E can do the sleeve install with LA sleeve parts.
Old 07-18-2016, 01:02 PM
Fast951's Avatar
Ahhh yes, my bad, the minor details. More precisely -- Flanged Liners with O-Rings are not used by AB and would be installed in my rebuild. Insurance against coolant seepage into the oil pan, however unlikely that event might be. These particular liners are difficult to source but can be found with the proper diligence.
Old 07-18-2016, 04:06 PM
RoverMasterTech's Avatar
You can grab a rock solid RR 4.6 out of a junkyard for $1000 - Who would buy one?
Old 07-18-2016, 05:31 PM
Fast951's Avatar
Not you, apparently.
Old 07-18-2016, 10:06 PM
abran's Avatar
^ You're back! And spreading joy I see!
Can't wait to see what ingenius fix you come up with next, keep us posted.
Old 07-19-2016, 11:36 AM
Fast951's Avatar
Maybe some of those 'rock solid' junkyard engines created the slipped liner plug welding approach? Man, I wouldn't let this guy work on my Schwinn.
Old 07-19-2016, 01:26 PM
JimmyChooToo's Avatar
He said RR 4.6. I don't think those slip.
Old 07-19-2016, 01:34 PM
abran's Avatar
LR had a block grading system. The best blocks up until 2002 were used on the range rover 4.6 motors, after that they only made 4.6s so it was a free for all.
Old 07-19-2016, 01:41 PM
I test drove a 2001 Range Rover HSE 4.6 with 122k. The engine was smooth as silk. Meanwhile My 2003 Disco II with 85k and the slipped liner can be heard from 2 blocks away. Yeah, I would agree they graded these engines just like Intel grades its chips.
Quick Reply: Top Hat 4.6 SAI Long Block Engine
