Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 02-03-2012, 02:34 PM
SolbergFanBoi's Avatar
Senior Member
Default Torque converter
Are the torque converters in our DII's electronically operated for partial/complete lockup of 4th gear or mechanical? Just wondering as I continue to have issues with 4th gear prematurely (@ 35 mph ) shifting into what would be used for highway speeds. This started happening when I changed the ATF to Mobil 1 Synthetic ATF. With a possible lower friction coefficient, it could be the culprit.
I have since changed back to a regular Dex 3, changed filter etc. and still experiencing the same thing. Lubeguard Black is up next to alter the additive package a bit to give it some friction modifiers to help get this thing figured out.
__________________
Drives:
2003 Land Rover Discovery SE7- 89k- Head gaskets and all servicable parts replaced @ 86k, front and rear prop shaft rebuilt. Next up: Transfer case, oil pump, chain, shocks.
2000 Porsche 911 Carrera
Sold:
1996 Discovery I
Old Man drives:
1995 Land Rover Defender 90 #2,683- 282k
Specialty: Engine oil and lubricant extraordinaire. PM me with your questions and for a recommendation
Old 02-03-2012, 03:48 PM
Send a message via Skype™ to Disco Mike
Any codes at all? Did you change the fluid this last time, if so, how burned was it?
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 02-03-2012, 06:46 PM
Senior Member
Quote:
No codes that I know of, no lights etc. Yes, I did the change to M1 and the ATF that came out looked like new. The M1 has been in there for about 15k miles and also came out looking like new. Would it be worth disconnecting the battery in hopes the TCM/trans would relearn it's shift points. I just feel it's mechanical if indeed the torque converter is locking up too quickly, if it's electronically controlled then I might be screwed.
Here are some interesting answers I got at Bob Is The Oil Guy forum:
"That really does sound like the transmission is expecting to have a friction-modified fluid and the TCC is just grabbing instead of smoothly engaging or going into a partial-lock mode. Modern (post 1990) transmissions do very complicated things with the TC clutch, locking it partway in some gears, and the slowly locking it as speed builds in final drive so it almost acts like a continuously-variable tranny. To do that most of them use friction-modified fluid to keep the TC clutch from grabbing or chattering. (like Mopar ATF+ 4, but there are many others)."
"if the M1 has a different friction coefficient, AND the LR is using a partial engagement, what's happening is that the partial lockup is now becoming a complete, or more complete lockup.
I experienced same in another vehicle. your AT wants a more friction-modified fluid. you can correct this by adding SMALL, CAREFUL amounts of LubeGuard Black. just a little at a time."
__________________
Drives:
Sold:
1996 Discovery I
Old Man drives:
Old 02-03-2012, 08:54 PM
Senior Member
From the RAVE shop manual:
The automatic gearbox is a four speed unit with electronic control of gear selection, shift quality and torque converter lock-up
and
Software in the EAT ECU monitors hard wired inputs and exchanges information with the ECM on a Controller Area Network (CAN) bus to determine gear shift and torque converter lock-up requirements. Resultant control signals are then output to the gearbox solenoid valves.
__________________
Old 02-03-2012, 09:38 PM
Senior Member
and
GREAT information! Thank you... Do you have an educated guess to what is happening?
__________________
Drives:
Sold:
1996 Discovery I
Old Man drives:
Old 02-03-2012, 10:11 PM
Philip Lawrence
Send a message via Skype™ to Spike555
I would do another drain and fill with regular trans fluid to get the rest of the Mobil 1 out.
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Old 02-04-2012, 06:44 AM
Senior Member
Agreed - it is certainly the least expensive alternative.
__________________
Old 02-04-2012, 10:33 AM
I also agree, with one addition, throw an bottle of Lucas tranny additive in the tranny to help clean up your valving and solenoid action.
DO NOT disconnect the battery unless you just want your different ECU's to loose their memories, leave them alone. Now if all else fails, then you might consider having a shop clear and reset your tranny's adaptive menory and then do a half hour of stoop and go city driving to let it re-educate it self.
__________________
Mike
Need Parts?
Old 02-04-2012, 12:48 PM
Senior Member
Will do guys, thank you for your thoughts. Will report back.
__________________
Drives:
Sold:
1996 Discovery I
Old Man drives:
Tags
2003, 90, 95, club, converter, convertor, defender, discovery, land, lock, partial, rover, se7, seal, soleniod, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
