Torque Specifications on wheel hub and bearing please :)
Old 11-25-2008, 11:43 AM
Quiksilver1850's Avatar
Default Torque Specifications on wheel hub and bearing please :)
As the title says, I need the torque specs on an '03 Disco... Drivers side front wheel hub and bearing. Thanks in advance!
Old 11-25-2008, 11:58 AM
redhotbuzz's Avatar
Default RE: Torque Specifications on wheel hub and bearing please :)
tightenadjusting nutto 61 nm back off 90 degrees tighten to 4......... locknut is 61 nm
Old 11-25-2008, 01:05 PM
Urban Panzer's Avatar
Noooo !!! those are for a D1 .....The D2 is different
The Hub securing bolts are 100 lbs ft, or 74 NM, but the problem lies with the axle nut
The D2 requires a Huge torque of 360 lbs ft or 490NM on the axle nut. So you need a biiiiiiiigggg torque wrench, either to borrow or buy.
Externet
08-26-2013 06:45 PM
Grlica
05-01-2013 06:13 PM
racerxnet
12-05-2012 12:00 AM
Prepilot_3ck
06-29-2009 11:43 AM
Quick Reply: Torque Specifications on wheel hub and bearing please :)
