Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 01-25-2012, 12:35 AM
Junior Member
Default Valve Cover bolts need tightening
I have an 04 Disco with a small oil leak. After much searching, I'm hopeful that it's just that the valve cover bolts need tightening. I bought a 8mm 12 pt socket, but then realized only the front passenger side bolt is easily accessible. I think I can finagle the back one, but what about the driver's side ones? How much of a hassle is it to get to them? Thanks for your advice. I know this is remedial, but I have to start somewhere.
Old 01-26-2012, 10:52 AM
w7412r's Avatar
Junior Member
To stop that annoying leak at the valve covers, I removed the valve covers, used sealant to attach the gaskets to the valve covers, let them dry, then place a bead of sealant at the top of the heads where the valve covers bolt on.
Tighten all eight bolts to 10lb/ft, and let the sealant dry.
It won't leak again if you use a good quality sealant. Permatex, or Hylomar.
Have fun!
Old 01-26-2012, 08:18 PM
Philip Lawrence
Send a message via Skype™ to Spike555
You only need to snug up the bottom ones, the oil does not leak out of the top, only the bottom.
Just snug the ones you can reach.
Do it at every oil change and you wont have any more leak.
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Old 01-27-2012, 09:54 AM
Send a message via Skype™ to Disco Mike
I agree, as a good rule of thumb, tighten those 2 bolts every oil change or twice a year and your will be fine, just realize, tighten them, do not over tighten them or you will cause other issues.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Tags
bolt, bolts, cover, covers, discovery, discovery2, land, leak, oil, range, rover, screws, size, socket, tighten, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
