Watt Linkage upgrade
Hello, I've had a lift kit on my D2 for almost 2 years now. It's a 3" suspension lift. My rear watts linage konked out a few months back. I just figured it was old and needed to be replaced anyway. I found another one from a wreacker that was off a stock low K's D2, put it in and my problem was solved but now after 2 months and a couple offroad trips my rear end is back to knocking again.
I've seen the bent arms from RTE but i'm wonding if anyone else has done anything to address the bind you get in the watt linkage set up when running a lift?
Even sitting in my drivway I can see the top arm is twisting slightly. I can only imagine what it must by like with full articulation climbing rocks.
I'm almost thiking of chopping the top arm in half and putting a slight twist on it to compensated this issue.
FYI my watt linkage gave out in the same spot both times. The upper arm mount on the diff section with the three holes.
Any thoughts? Anyone done anything to fix this?
The bushing are not cheap for these and I don't want to replace again to have the same problem so quickly. I'm seeing bushing kits for around $200 and that wouldn't include hours of pounding to get the old ones out.
Lucky8 Llc. - Take the road less traveled...
Looks like the trailing arms & panhard arms that I built for my old Trans Am. You can get the rod ends (bush or spherical) and pre tapped tube stock (metal or aluminum) from Coleman Racing for cheap!
Trailing Arm, Aluminum, Coleman Car
