wet driver floor and driver side passenger floor
Check the fire wall seals around the steering shaft or any missing seals or plugs. Open the bonnet and use a water hose around the windscreen and a light to check for leaks under the dash. Next check the drain on the drivers wing ,the side wing(fender) can fill with leaves,twiggs and plug the drains which will cause water to enter the cabin a the drivers kick-plate. Also check the door seals.
I'll check the drains.
The horn issue was just a stuck switch on the wheel. I recall bumping it and making it sound earlier in the day then next day it was cocked in and on. Just pushed it and fixed. I think the temp drop in the night made the close contacts connect and that is the delay. I neglected to go back and update my post on this though. If you pull the horn fuse the cruise will not work but the light on the cruise switch will go on.
bcolins
06-28-2013 08:28 AM
Spencerfitch
05-03-2010 02:56 PM
