What 180 thermostat can I buy for the Inline Thermo Mod?
Yes, the gates hose will replace your lower radiator hose, but will have to be cut to fit.
Re: thermostat - get a jiggle pin one, and forget the holes. in a hot climate, the inline therm mod will throw a code if you drill out too big. I forget the number, but basically it allows too much difference between temp sensors and the ECU gets annoyed.
I did this setup on my last 2002, and in phoenix, where its hotter than the devil's skillet, it stayed pretty darn cool even with AC on. 201-202 idling.
Debating whether to go this route, or the rover gray one on the newest disco.
There are a couple good writeups on here with pictures, have them handy on your iPad when you start this. If you have all the parts, it takes under 2 hours.
One word of caution - when you do this the first time, you will have a leak.
Or two. Or three.
Fill your system with distilled water the first time around, and drive for a bit. Leaks will come up, and you won't be spraying coolant all around, and distilled H2O is about $0.75/gallon.
Or two. Or three.
Okay guys so I have all of the parts now to do this job. One question though. I have no idea how the felpro12994 gasket fits into the new thermostat housing. It also looks like I would have to cut it to make it fit inside the thing to. Doesn't really seem like I need it.
Can someone clear this up for me?
Also, spring side goes towards the engine? And the rubber o-ring that comes with the meziere housing sits in the female half right?
Try to use the opportunity when playing with hoses, to implement a coolant drain at the lowest point.
By the way, ----> 90 Degree Inline Thermostat Installed. Photo by Innernet | Photobucket
----> 90 Degree Inline Thermostat Parts Photo by Innernet | Photobucket
Yes, spring towards the engine.
The best way to bleed air is not needing to bleed air...
----> In-line Filler Neck Photo by Innernet | Photobucket
Alright guys well as far as I can tell I've installed everything correctly but my temperatures have not improved. The spring is pointed towards the motor, every hose clamp is buttoned down.
I replaced the temperature sensor while I was in there. When I got it all started up again the ultra gauge was saying that the engine was only running at 110F. Which had to be BS so I put the old sensor back in and got better readings.
I'm going to up to 210 faster than I did before the mod. I revved the motor to try and circulate the coolant but it only had a minimal effect of a few degrees. I found a leak in the coolant expansion tank. Its leaking at the bottom where I sealed it off years ago. I bypassed the throttle body..
Please chime in with suggestions as far as what to check. I've bled the system a few times now. The expansion tank is dripping coolant but I can't see how its responsible for these temperatures.
