Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Search
Old 12-09-2008, 05:02 PM
Member
Default what is code p1590 ?
I had a autologic read my faults today. It read P1590 And the tech said it was abs ecu failure. He also sadi the ecu may have damaged some wiring. I am wondering what i should do next. I was going to spend the money on an ABS modulator Kit for 800.00 from rover parts but i do not want to purchase the wrong part. I have already tried the cheap fix ( shuttle valve kit) and that did not work .The tech says i need an ECU ..Is the ECU on the computer side of the MOdulator. Would appreciate any helpCaleb
__________________
caleb
Old 12-09-2008, 05:23 PM
Senior Member
Philip Lawrence
Send a message via Skype™ to Spike555
Default RE: what is code p1590 ?
The cheap shuttle valve kit never works, you must use the expensive one.
DiscoMike knows more about this than I do, but I highly doubt that you need a new ECU.
__________________
The "Storm Trooper", 1997 Discovery with 225,000 miles, still a daily driver.
Old 12-09-2008, 06:45 PM
AK Rover's Avatar
Senior Member
Send a message via MSN to AK Rover
http://www.troublecodes.net/landrvr/
Gives all the codes for the Land Rover OBDII system. I found it pretty helpful
__________________
To download the RAVE manual, follow this link http://www.landroverresource.com/
Old 12-10-2008, 10:41 AM
Send a message via Skype™ to Disco Mike
1590 is a rough road/ABS fault that normally will also show up when the ABS is having problem with the lights coming on and off or on all the way.
It can be clear with a proper scanner and is not being caused by any other ABS part.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 04-03-2009, 11:53 AM
Member
Hey mike.. I was doing some searching on this code ,witch I now have, and you say here it has something to do with the lights. Can you explain further on how the lights play a part in this code. Is it the warning lights not activating correctly or something else?
I had to re-register today whats up with that?
Thanks man,
Jeff
Old 04-03-2009, 12:49 PM
The 1590 code is a Rough Road/ABS fault only indicating the the 3 Amigos are on or come on go. Fix you brakes and then you can clear the code.
__________________
Mike
Need Parts?
Old 02-04-2013, 07:43 PM
Junior Member
Disco mike, hi I'm norm and I had this code come up along with three lights. The abs, traction control, and decent light. They came on after I wash it and started it to go somewhere. Any idea why this is?
Tags
1590, 99, abs, cheapest, code, discovery, fault, ii, land, obd, p1590, p1590land, rough, rover, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013 vBulletin Solutions, Inc. All rights reserved.
Emails Backup
