#2111
Picked up my heads from the machine shop. Wow, they are clean. I set them in place and threaded the ARP studs in. Still need to install the oil pan and all the other items that need to be put back on when doing head gaskets. I hope to get it together this weekend, 4 weeks and $1K from tear down.
#2112
hey guys my service light came on my 03 disco and i have a couple codes that i was hoping to get some advice on, one is for my 02 sensor code P0134 no activity detected on bank 1 sensor 1 so i am going to check the wiring then maybe replace, do you know if that is the passenger side closest to the exhaust manifold? The other code is a p0327 knock sensor 1 circuit low bank 1 or single sensor. i have no idea where that is, i herd that they can get clogged and can be cleaned any ideas are much appreciated. thanks
#2113
#2114
Hey guys just got a used compressor from Paul Grant. I have question about what to do after install. I can tell the compressor has leaked oil from shipping but when I get it installed does simply not using the AC guarantee that the compressor will not be on internally until I get to an AC shop to refill it?
If I leave the the multiplug on the compressor disconnected will that allow the bearing to spin freely while leaving the internals off?
Also I replaced my AC drier only a few months ago. I'm going to have to drain the AC to install the compressor. Will I really have to replace the drier again as well or is it new enough to get by with it?
#2117
#2118
Well I havent installed the new compressor yet so I'm going to have to drain the system myself. I take it there would be no saving the ac drier once I start taking the hoses off?
One more question for you guys today. My new airtex water pump is going to arrive today. Can I use RTV on this or does the gasket need to be dry? If I can use RTV, do I use it on the pump side/front cover/or both? Really looking forward to getting the looming worry off my back about the cooling system. Once I do the pump and radiator I should be set for a good while. Knock on wood.
Thanks
#2119
#2120
