What is the point of buying extend front bump stops
I was thinking something similar, I have this issue where after I installed my 2 inch spacer lift and I hit a pretty descent bump in the road I have this very solid and loud banging noise. Later on I figured out it was my axle hitting the frame or something like that. I was wondering if longer bump stops would fix this.
justinfignewton (05-11-2021)
I'd check all the bolts on your suspension to find the banging sound.
No. That makes no sense. Your 2" spacers are pushing the axle 2" farther from the stock bumpstops. You extend your bumpstops so your tires(usually larger with a lift) don't rub the wheels arches or your shocks don't bottom out.
