will not engage in PARK
Old 04-28-2016, 03:05 PM
Lost's Avatar
Default will not engage in PARK
I am extremely green. With that being said, I picked up a 03D2 a couple of weeks ago and have been slowly understanding how much work I have to do. What I am unable to locate is a thread or video explaining the aforementioned problem. Further details:
Putting it into any other gear it works and acts as it should and when it is in PARK it allows me to remove the keys, so in that regard the vehicle acknowledges that the vehicle is in PARK. However, if I release the foot brake or I do not have the parking brake pulled up, it will start rolling. It, in that sense, acts as if it is in neutral. I have not heard anything, felt anything, or smelt anything when ever I "shift" it into PARK.
Thanks
-Lost
Old 04-28-2016, 03:25 PM
Daedrix's Avatar
How far does it "roll"? Are we talking about it will roll down a hill?
Old 04-28-2016, 04:02 PM
Lost's Avatar
yeah it will roll down a hill, backwards and forwards. It makes no sounds, no clicking or whining. The farthest I have let it roll is maybe a 100 meters or so.
Old 04-28-2016, 06:06 PM
Charlie_V's Avatar
I have never delved into my transmission but I'd say you have one of two problems. The selector cable is out of adjustment (driver side of transmission). . This should be easy to check. Just see if you can manually move the part that the cable goes to to get into Park. Under the truck. The other is the mechanism or pin that immobilizes the transmission. That's beyond my knowledge.
Old 04-28-2016, 08:15 PM
number9's Avatar
Here's a manual reference for simple cable adjustment.
File Type: pdf
Old 04-29-2016, 12:31 PM
drowssap's Avatar
On an American transmission it would be called a broken parking pawl ( do a search) who knows LR calls it.
Old 04-30-2016, 06:58 AM
rankar's Avatar
If you're going to go in exploring under your gear selector (from the cabin, not underneath), then ditch the interlock solenoid. One of the best before-an-emergency mods to do.
Old 05-09-2016, 10:33 PM
Lost's Avatar
How do I ditch it? What do I replace it with?
Old 05-09-2016, 10:51 PM
Charlie_V's Avatar
When you pull the **** off (pull up, hard) and carefully pull up the gear selector face you will see a little rod that keeps you from pulling it out of park until you hit the brake. It is a "feature" that leaves people stranded sometimes. Once you see it, you'll see how you can push it with a finger.
Old 05-10-2016, 08:55 AM
jbarr89's Avatar
I'm sure it goes without saying but be careful that your face is not above where you are pulling; I've seen people pull the **** off and pop themselves in the mouth! Not judging your intelligence at all, just laughed a bit when I read this comment from Charlie_V
Quick Reply: will not engage in PARK
