Yet another door lock issue
I have searched on here and found several threads that generally address this issue but, none of them ever seemed to resolve the problem.
My 02 Disco locks will not work with the key fob, when I try to lock it I just get a beep from the horn as if one of the doors is ajar. Also, the dome light stays on and the warning tone continues to sound with the key in the ignition but all the doors closed. The central locking switch will unlock and unlock all the doors except the drivers door. I can lock the drivers door manually with the key and use the central locking switch to lock the others but this is annoying. It is acting as if, whatever reports to the computer that the drivers door is closed, is not doing that. My question is, what tells the computer that the door is closed?
Thanks for any help...I'm not really stupid, just new to Land Rovers and a bit stubborn which can often look just like stupid.
Hildy
Hildy
Thanks for the tip. I checked the switch for the hood and found that it was not working. I bypassed it but my problem is exactly the same. I'm starting to think that my fix is going to be changing the actuator in the driver door.
Well, I am back with the same issue. I replaced the door lock actuator with a new one and the issue is the same. When I use the key fob the only thing that happens is a beep from the horn. The dome light will not go out, and the door alarm continues to sound when the keys are in the ignition and the door is closed. I can lock all the other doors with the central locking switch and lock the drivers door manually, after that the central locking switch or the key fob will unlock all the doors including the drivers door. For some reason the computer thinks the door is not closed when it is.
dogparc
01-03-2012 04:38 PM
