Engine & Internal Chat about beefing up your engine's insides here.
Engine overheated and H2O emulsified with oil
Old 12-02-2015, 02:38 PM
LRDISCONEWBIE777's Avatar
Default Engine overheated and H2O emulsified with oil
As the title states.
Engine is ticking. Cranks right up. Water pump is working. Flow through the radiator. Coolant is being recovered.
Old 12-02-2015, 02:43 PM
Had the coolant system serviced 6 weeks ago. I should have done it myself. The temp shot up through the roof on open highway. I replaced the thermostat before this happened.
Old 12-02-2015, 02:54 PM
uoflcardfan77's Avatar
Sounds like a cracked block, or head. Water and oil should never mix, especially in an internal combustion engine.
I would not start and run the engine until I had it checked out.
Old 12-02-2015, 02:58 PM
Yup. Nope...she has sat still ever since last week. Probably will stay that way. I say that it is time for an engine upgrade.
Jabez
02-06-2012 02:56 PM
agthird
08-16-2010 10:46 AM
2fast4u
LR2
12-07-2009 08:42 PM
no limit
09-12-2007 11:32 AM
dlkk
08-03-2007 09:12 AM
Quick Reply: Engine overheated and H2O emulsified with oil
