Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Brand Reviews > Engine & Internal
Register Forgot Password?
Old 03-28-2006, 06:19 AM
Junior Member
Default Low oil pressure
re : 1987 LAND ROVER LR 90 DEFENDER
When driving the oil pressure is ok but on idle its about 5 to 10 on the gauge - the bottom end sounds ok ? Is this a major cause for concern ?
Many thanks
NB.
Old 04-16-2006, 11:26 AM
Junior Member
Default RE: Low oil pressure
The drop in oil pressure at idle is typically due to increased rod and main bearing clearance.
Extra clearance due to wear in the oil pump housing will also create this situation.
At higher engine speeds the pump moves enough oil to maintain pressure dispite the wear.
The engine may operate like this for extended periods.
Replacing the pump may postpone the needed rebuild.
__________________
www.ewingmachine.com
Old 05-18-2006, 03:23 PM
Send a message via Skype™ to Disco Mike
You need to do a mechanical oil pressure test to verify the real pressure numbers, then you might consider doing a good engine flush to see it it will improve, if that doesn't help, pull the oil pan, clean and inspect, especially the oil pick up tube that are known to plug up.
Mike
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Tags
defender, engine, flush, idle, increase, land, low, lr2, oil, pressure, reviews, rover, wwwewingmachine, wwwewingmachinecom
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
