Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Brand Reviews > Engine & Internal
Register Forgot Password?
Old 08-04-2011, 03:37 PM
Junior Member
Default removing oil pan
can someone tell me if the oil pan can be pulled while the engine is in the car on a 2006 land rover, supercharged engine?
Old 08-13-2011, 01:56 AM
Senior Member
no it can not you either have to drop the sub frame wich ive seen only done once and not too fun. ive done a complete engine reseal on these about 20 times and all 20 times it wasnt fun, taking the engine out is your best bet. since the torque sequince is very important. why are you removing the pan?
Old 08-15-2011, 10:32 AM
Junior Member
My son in law drove the car while it was low on coolant and resulted in a overheated shut down of the engine, at this point i am fairly sure of at least a blown head gasket. I have not pullud either of the heads yet as i have'nt had the time to get involved.The bottom end might be ok but i just don't know.The engine runs but is missing, i was wondering what was involved in pulling the pan, if it became necessary. Thanks for the info.
Old 08-16-2011, 10:59 PM
Senior Member
even if you pull the heads off i suggest to remove the engine for better access and easier to work on. what codes does it have?
Old 11-04-2011, 06:31 AM
Member
Any updates?
__________________
2001 Land Rover Discovery II SE White
1996 Hyundai Accent
1981 Ford F-250
1969 SS Chevelle
Old 11-17-2011, 03:27 AM
Athena's Avatar
Junior Member
Send a message via MSN to Athena Send a message via Yahoo to Athena
take it
__________________
Early to bed and early to rise makes a man healthy, wealthy, and wise.
Tags
1969, 2001, 2011, change, chevelle, discovery, engine, land, located, oil, pan, range, removal, remove, removing, rover
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
