99 disco 2 running hot but not showing on temp guage. - Land Rover Forums - Land Rover Enthusiast Forum
Old 12-09-2016, 07:47 PM
Junior Member
Default 99 disco 2 running hot but not showing on temp guage.
bosch 4.0. Started to get hot on the way home from work, stopped and put water in to cool down. took some jugs with me to limp home stopping frequently to put In more water. overheating light came on once for about a minute during all this time but water seemed to be boiling out. Replaced waterpump thermostat elbow pipe and radiator. Now overheating quickly with temp gauge showing running temp, went to a shop to help me bleed the system with no luck on stopping the overheating. Temp gauge reads normal with water boiling out. head gasket? warped head? cracked block?
Old 12-14-2016, 06:43 PM
Member
I guess I will chime in first. First the temp gauge stinks in this vehicle, it really has three positions, cold, middle and overheated. I would bet you need a new head gasket, but a coolant pressure test or engine compression test should be done to confirm. Anytime I have done a head gasket change (just did one on my disco) I assume the heads are warped and get them decked. It's not much more to get a place to deck the heads and it would be a shame to do the head gasket only to find out the heads are warped after you get it all together.
Thread Thread Starter Forum Replies Last Post
Rover Running Hot, But Dash Temp Gauge is Normal GoingPlaces Discovery II 12 06-15-2015 09:25 AM
changing the temp guage to show real temp 2Discos General Tech Help 27 09-09-2013 04:23 PM
running hot but not overheating Mojigglins Discovery II 10 02-13-2013 10:14 PM
was showing P1193 and P1138, now showing P1191 and P1138...???? philander Discovery I 13 08-19-2011 04:20 PM
Temp Guage High on Start up on 03 Disco dgm General Tech Help 3 07-20-2011 05:20 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
