If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
Hi,
New member here and I am having a hell of a job in getting into the forum. I can only do so by responding to an email from a thread I somehow got into.
There seems to be no place to actually log in securely either.
Is this an a US based site?
I used to live in the US and maybe my browser is confused but whatever I need elp.
Hi,
yes as you can see I have this problem.
It appears no one monitors this either as I have not had a result or a response and I have fired one or two out there on this subject.
I can't seen to access and input there either.
Very odd indeed.
Does one have to be a donor to gain access?
There seems to be no place to make contact with the admin or monitor?
I could of course just be missing the tabs and am being completely thick!
there are people from the UK on this forum. check your security settings. make sure you are trying to login at the main page of the site. www.landroverforums.com
the login is near the top right. also... how the hell did you get a visa to move to scotland from the US? i tried to move to england a few years back and it was near impossible.
but one thing how did you post here if you were not logged in? i believe you need to be logged into post anywhere on the forum.
__________________ -Ed
99 DII, TF +2" HD & steering damper, TreadWright 265/75/16, ARB front, BritPart rear, Warn m8000 with synth, Columbia Overland gate panel & dual battery tray, Safari snorkel, RoverBones diff guards, RockWare sliders, DieHard Plat Deep Cycle, Chalkboard Headliner, CB, Wilderness Rack, 6 hella 700 ff's w 100w bulbs, 2 hella work lights
93 RRC TF track rod, tie rod & steering damper, TRW rims
Need Parts? paulgrant@mac.com, or 203-770-1699 willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Hi
I am a UK Citizen anyway.
There appears to be nowhere to log on.....only to log off.
It appears to recognise me but I am unable to navigate and look at a thread.
Only way is to respond to an email from the likes of you, a member.
I have been communicating from someone from Germany. The fact that I come from the UK should not be a problem?
Help!
