Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Freelander
Register Forgot Password?
Old 08-25-2011, 05:34 PM
Junior Member
Default 2005 Freelanerd Help.......
My Sisters only car is showing me the following codes.
P0306
P1300
P0661
P0302
P0305
ANY IDEAS SHE JUST SPENT ABOUT 1200 IN TIRES AND NEX AXEL TO GET THE CAR ON THE ROAD NOW THIS.
Old 08-28-2011, 02:13 PM
Senior Member
did it get a fuel pump recall? if not try that and then check the obvious connections like vacuum hoses and other stuff. Finally check the vehicle is firing on those cylinders and not some sort of moisture getting into the cylinders.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Tags
05, 2005, bad, code, dtc, freelander, freelanerd, fuel, land, oem, p0661, p1300, po303, po305, pump, rover
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
