Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Freelander
Register Forgot Password?
Old 11-01-2010, 10:32 AM
Member
Default Another Freelander Coolant Loss Question
I've done a search, but haven't come across anything that answers the question I have with a friend's 04 Freelander that I'm working on.
60,000 miles, overall excellent condition. Uses about one quart of coolant every 1000 miles. No coolant in oil, no oil in coolant, no liner noise, compression on all cylinders between 160 and 180 psi. There are no visible leaks, and no white smoke or sweet smell in the exhaust. Thermostat is OK, and is not leaking into valley between cylinders.
I read somewhere that it is possible for the intake manifold gasket to allow coolant into the combustion chamber, but only during certain conditions. Has anyone had a similar problem or situation?
__________________
Rick Tonder
03 Disco - 90K Drive every day.
02 RR - 45K A big sissy.
04 Freelander - what a joy.
Old 11-03-2010, 06:30 AM
Senior Member
cap and tank does it alot. but look at the heater core under the dashboard. if you see coolant on the fan sticker its bad.
when in doubt add coolant dye.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Old 11-03-2010, 01:36 PM
Member
Thanks for the tip. I've ordered a tank and cap, thinking it may be the culprit since the motor has been set up to run so warm and any loss of pressure from the cap might cause it to boil away.
__________________
Rick Tonder
Old 11-13-2010, 08:08 PM
Junior Member
Same thing with me. Needed new engine at 75K, fortunately under warranty.
Tags
add, adding, chamber, combustion, coolant, core, freelander, heater, intake, losses, manifold, noise, problems, smoke, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
