Freelander Talk about the Land Rover Freelander within.
Antenna
Old 06-04-2005, 08:44 PM
moda27's Avatar
Default Antenna
Hey all, my sister just picked up a Freelander (loves it!). But do you guys know of an aftermarket shorter antenna? The stock antenna is too long and hits the garage door, so when she backs out she has to hold the antenna down (from the sunroof) so it doesn't possibly "snap" off if that makes any sense. Thanks.
Old 07-03-2005, 07:13 AM
MoneyFor's Avatar
Default RE: Antenna
I removed mine and change it with a very short one that I bought in celphone shop. Will try to post a pic of it.
Old 07-03-2005, 07:23 AM
MoneyFor's Avatar
Default RE: Antenna
Here they are:
Old 07-03-2005, 07:30 AM
Lighting90's Avatar
Default RE: Antenna
Just lay it flat, it should still get good reception..
Old 08-24-2005, 12:43 PM
jholdaway's Avatar
Default RE: Antenna
I don't get a good signal with it up or down
Old 08-24-2005, 04:52 PM
mikemeyer0's Avatar
Default RE: Antenna
how about replace with a power antenna, you can order them from lots of places, I don't remember where the antenna is on the LR3's but if theres room that would work.
Old 12-21-2008, 02:57 PM
trentmelton's Avatar
Default RE: Antenna
Does your sister still have the original antenna? I'm looking to buy one to replace mine that was stolen. Contact at trentmelton@hotmail.com. Thanks.
Old 12-25-2008, 06:12 AM
2002 freebie se's Avatar
Default RE: Antenna
The antenna can be adjusted to lay flatter, or raised higher, at the base. All she has to do is find the position that will ride low enough, so it doesn't touch the garage door.
Old 10-21-2014, 06:56 PM
tfmmai's Avatar
how do I adjust the antenna up and down for a 2003 Freelander? It is stuck in the up position and will not budge.
HerbD
06-14-2006 02:52 AM
kidsdoceks
04-29-2006 06:41 PM
xb70valkarye
01-30-2006 06:40 PM
adowgiert
Audio/Visual Electronics
10-31-2005 05:17 PM
mikemeyer0
05-26-2005 01:44 AM
Quick Reply: Antenna
