Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Freelander
Register Forgot Password?
Old 11-02-2010, 09:49 PM
Junior Member
Default Bleed valve- 2003 Freelander
Good night Rover experts,
I am running into a problem. I own a 2003 Freelander. About 2 months ago, I flushed the radiator, and added coolant. In the process, I forgot to put the cap, and drove about 400- 700 miles without it. Now, 2 months later, the AC/ HEATER air is not coming out. I believe it is a result of air in the system. I have read online on how to take air out. Some recommended to bleed the air through the valve. I cant find it. Can someone shed some light on where it would be? Moreover, can someone provide guidance on whether bleeding might solve my problem (AC/HEATER). If you have some pics or the manual diagram to share with I would appreciate.
Thank you
Old 11-03-2010, 06:29 AM
Senior Member
its at the back of the engine look for two hoses going into the firewall. open it up and pour coolant until the coolant comes out and stops bubbling out.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Tags
03, 2003, air, bleed, bleeder, bleeding, coolant, cooling, drain, freelander, heater, land, rover, system, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
