If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
Looking into possibly buying a freelander for my wife but I am reading a lot horror of stories about these things.
Is there a reason why so many of them I found have a new engine?
I hear a lot of complaints about headgaskets can this be fixed with better gaskets?
Any pros and cons would be greatly appreciated I myself am a discovery owner with over 200,00 miles on it my problems have been minimal I fully believe I will get over 300,000 out of it..
Nothing was improved. The same garbage was thrown into it. All four speakers blow out, all five windows are known to go and they are really expensive. The latches stop working. The transmissions are junk, the engines are junk, no headgaskets won't do squat as the the sleaves slip and the heads pit and cause coolant loss. The cv joints go bad, the suspension goes out.
Trust me, we in LR up to the corporate level was happy when the last one went out of warrantee.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Wow...Am I glad I read this thread. I just totaled my Blazer and have been talking with a dealership about an 01 FL. Looks to be in great shape, but I think I'll pass.
You will be better off doing that. I am passionate about Land Rovers, but every time I see a Freelander on the roads, I think how much money the driver has or will have to invest into repairs.
__________________
2000 Disco II 113,000 miles
Maintenance: 60K service with BG fluids, front drive shaft rebuild, Denso iridium plugs, front O2 sensors, Akebono ceramics front and rear with new rotors, belt tensioner and idlers, brake fluid and coolant flushed every two years- regardless of miles
Upgrades: OEM brushguard and driving lights, 04 CDL, extended rear axle breather, DI wiper arms, heated seat kit, grey painted chalkboard headliner
