Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Freelander
Register Forgot Password?
Old 07-20-2010, 11:31 AM
Junior Member
Default Engine is a mess
I have a loal dealer that did a repair on my Freelander trying to give me a story about why my engine is ruined. They worked on my engine due to leaking oil and found the cam seal leaking. They replaced the front and rear cam seal but lateradmitted thedid not adjust the timing belts. They are now trying to tell me the engine had an exhaut lifter missing and that is the reason the engine needs to be rplaced. I need some help with this situation.
Old 07-22-2010, 09:14 PM
Senior Member
no, lifters don't go missing.
but if the seal blew out I bet ten bucks the rings were bad and blew the seals.
Did they replace the cam seals or the big caps?
Besides they are responsible if they chose not to adjust the timing.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Tags
bad, blew, cam, camshaft, freelander, land, replacing, rover, seal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
