Freelander Talk about the Land Rover Freelander within.
freelander -radiator cooling fans
Old 07-15-2005, 06:05 AM
SARAH1's Avatar
Default freelander -radiator cooling fans
After having recently changed the clutch and also the fly wheel, the radiator cooling fans are sticking on adn the car sounds like an aeroplane. Having contacted my local dealer they advised to plug and unplug then restart, i have checked and removed the silver box, had the fuses out and leads. Still nothing. I cannot get booked into my dealer for 2 weeks.
Can any one help and advise urgently??
Old 10-01-2005, 09:12 AM
rinmud's Avatar
Default RE: freelander -radiator cooling fans
Two posibilities, obviously your in canada becuase Ive never seen a stick in the states but there may be. 1) the fan control box in between the fans is burned out (the silver thing). 2) there is a red relay beneath the radio and control panel that activates the fans when the a/c on button is pushed to cool the condenser its probably full of water from condensate drain being plugged. There is a recall for the condensate tube.
Old 10-01-2005, 07:54 PM
2003FreelanderSE's Avatar
rinmud, are you a LR Tech? I'm referring to the answer to the TC/HDC post. If so, good to have an inside perspective here! FYI, in Canada we get US spec vehicles - no manual transmission products have been sold here since the '95 Discovery.
Old 10-29-2005, 12:09 PM
bonnettoboot's Avatar
Sarah; What was the outcome? Forget the dealer, search around for a good independent mechanic,
________
dispensaries
Old 10-30-2005, 12:05 AM
Bait's Avatar
SARAH1 is referring to a UK vehicle.
wilson96rr
05-31-2009 10:07 PM
imgoingup
08-03-2008 08:57 AM
Rfactor
01-21-2008 10:17 AM
jmt
12-23-2007 06:16 PM
stanigu
08-23-2007 09:39 AM
Quick Reply: freelander -radiator cooling fans
