Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Freelander
Register Forgot Password?
Old 07-28-2011, 01:26 PM
Junior Member
Default heater blower
i have an 02 freelander
the problem started last week ..driving along the fan started to slow down and eventually stopped all together
i checked both fuses and ok
there is power going to fan
i removed the fan and let it sit out for a day cleaned with an air shot
put back in and it ran for about 10 seconds and slowly slowed to stop ..
any thoughts ideas please its 95degrees here in NYC
Old 07-29-2011, 07:42 AM
Junior Member
do the bump
Old 07-31-2011, 06:16 AM
BritishByProxy's Avatar
Junior Member
Second hand blowers are cheap, and take about 5 minutes to install. Had to do mine this weekend. Three screws, pull it out, put the new one in. Easy fix.
__________________
"That's not gone well, has it?"
2002 Freelander SE 85,000 miles
2000 Discovery Series II 142,500 miles
Old 07-31-2011, 01:47 PM
Senior Member
Easy, no reason being is the fan goes because of a coolant leak in the heater core. if their is coolant on the fan then you need to pull the dash board and install a new heater core and fan.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Old 07-31-2011, 05:44 PM
Junior Member
My appologies to all,
My heater core had already been fixed, and the motor was all that remained to complete the job. As a leak hadn't been mentioned by Rabid, I assumed this issue had already been addressed in his vehicle as well. Of course, a leaky heater would need to be corrected before replacing the motor. Fix the cause, not the symptom, right?
__________________
Old 08-01-2011, 09:23 AM
Junior Member
Default my fix
i took the blower out again and gave it a wd 40 bath left it for a few hours and then dried with compressed air .replaced it and its up and running good as new ....? dried gunk from the heater core maybe ?
Old 08-05-2011, 10:18 AM
Junior Member
Default fan blower
so i got the fan working better than ever ...3 days no problems
then i was crossing the williamsburg bridge stuck in traffic and i hear the fan slowing down and eventually stopping ..all speeds for about 30 minutes ..all fuses ok
is the fan over heating / over working
i am in NYC its 95 degrees and most of my driving is bumper to bumper 20 miles an hour ?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
