Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Freelander
Register Forgot Password?
Old 07-26-2010, 12:37 PM
Junior Member
Default IRD or Rear Diff?
My freelander just started thumping and clunking worse when turning but I cannot pin point it sometimes it sounds like its comming from the front end but other times the rear end
Its so bad I cannot drive it on the road how can I tell if the half shaft are cooked it might be these ???????
Old 07-26-2010, 08:48 PM
Philip Lawrence
Send a message via Skype™ to Spike555
You need to have all the driveline fluids changed TODAY and hope it is not to late.
There is a fluid couple in the middle of the car that transfers power from front axle to rear axle as you drive.
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Old 07-31-2010, 07:38 PM
Senior Member
If it clunks you can check the rear diff bushing. its near the driveshaft. Many of those break around the bolt. But its possible you also have a loose sway bar link or something else in the front suspension. Have the vehicle put on the lift and inspected.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Old 08-01-2010, 10:23 AM
Junior Member
Its the IRD unit so I just picked one up at the wreakers for 350 I might have to check the drive shaft now to see if that VCU failed
Im now drivin with FWD I took the drive shaft out
Old 08-01-2010, 10:25 AM
Junior Member
How do I find out if the VCU has failed ? its out of the truck right now
Tags
2000, 2007, axle, bad, clunk, differential, discovery, freelander, front, ird, land, landrover, lr3, rear, rover, suspension, thumping, turning, vehicle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
