Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Freelander
Register Forgot Password?
Old 02-16-2012, 12:55 PM
Junior Member
Default Misfiring Freelander 2003 Serengeti 2.0L TD
Hi there Am after some help my freelander serengeti 2.0L TD 2003 is misfiring . Sometimes the problem is worse than others to the extent the engine will not start. The Engine light keeps coming on itermmitently. Its been through an electronics diagnostic and only thing that showed was reduced pressure (which is obvious). Air filter has been changed . Any suggestions or advice would be much appreciated
Old 02-25-2012, 06:27 PM
Junior Member
Do you have a regular shop that takes care of it? I would check the plugs first for the fault. If that is it, then you want to know why the plug is gone. Be especially afraid if it is using coolant.
Old 03-19-2012, 04:20 PM
Junior Member
do you have the OBD II codes?
Old 03-20-2012, 10:15 AM
Junior Member
I don't know if you can find the codes here, but they can be found on the internet, didn't see them in my RAVE CD, I also think you can find them in the sticky section at RangeRovers.net
Tags
2003, 2l, computer, freelander, land, make, misfire, rover, serengeti, td
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
