Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Freelander
Register Forgot Password?
Old 08-23-2009, 08:49 AM
Junior Member
Lightbulb Problem with starting 2003 Freelander SE
I have tried everything for this vehicle to start. I have changed the Spark Plugs because the car started shaking like it needed new plugs. So, I put new Spark Plugs. I tried turning the key to no avail. Never even made a sound. I checked the starter it checked out ok. I in turn checked my relays they checked out ok. Now, I noticed that when I turn the key the Ignition gets very hot. Is this normal ? The car is still sitting out in the front of the house. I need some help with this problem that I seem to get most of the time with this vehicle.
Does anyone have an idea of this dilemma ???
2003 Freelander SE
Old 09-02-2009, 08:44 PM
jeffzx9r's Avatar
Junior Member
If the ignition is getting hot, I would suspect a short in the wiring. Any aftermarket add-on amperage-suckers or new auto parts store gizmos that have been hacked into the wiring harness?
Welcome to the world of Land Rover!
Old 09-11-2009, 07:04 AM
Junior Member
It Could be a resistor pack problem or a short circuit in wiring , so check all wiring to the coil and fix the problems.
__________________
used vehicles
Tags
2003, common, delay, engine, forum, freeelander, freelander, land, modifications, problems, rover, se, start, starter, starting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
