Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Freelander
Register Forgot Password?
Old 06-16-2009, 08:50 AM
Junior Member
Default starting problem
Hi i have a freelander TD4 GS 2001,it starts 1st time every morning yet if i go on a short journey stop turn off an return half hour or hour later it w'ont start, i then have to leave it 15 mins or up to an hour then it will start no probs always ok when on a cold start, any ideas its very frustrating HELP
Regards Alan
Old 07-20-2009, 08:24 AM
Junior Member
Hi Alan i have a 2000 td4 Freelander also with the exact same problem. I had mine looked at and it had no fault codes or anything. The mechanic had it for a few days and found it difficult to get the car to fault at first as onece running it does not skip a beat. Its only when it has stopped after a short journey and a quick return it will turn over and not fire. Does your heater light come on all the time or is it intermittent like mine? Mine will sometimes not light up at all but still start and then next day they will light up like a xmas tree. If you find a cause would be grateful if you let me know.
Darrell
Old 08-08-2009, 06:10 AM
Junior Member
Alan
I have recently had my car repaired at a land rover specialist. It had the same problem as you described.
Fault repaired was a camshaft sensor that would allow it to start a few times but would then not read the signal.
Cost of repair £151.00 well worth the money for peace oif mind when going out to the car to start it and it goes everytime.
Hope this helps if you have not had yours repaired yet!
Darrell
Old 08-21-2009, 05:38 PM
Junior Member
Default Freelander Ignition Switch
I have a 2003 freelander that when I changed the Spark Plugs, will now not start. When I turn the Ignition Switch it does absolutely nothing. I have checked the Starter, the Plugs, the Relays and now I noticed that the Ignition Switch is very hot when I turn the key several times. This was happening before all this happen, when I removed the key from the ignition my key would be very hot. I need help in instruction in how to removal the entire Ignition Switch from the vehicle ? Someone please help ?!
Tags
freelander, land, problems, rover, starting, td4
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
